Failed to enable all-multicast mode for an interface.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
Failed to enable all-multicast mode for interface %p1% Error code = %p2%
| Name | Type |
| p1 | uInt32 |
| p2 | sInt32 |
